Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-14-2009, 09:03 AM
car_junkie car_junkie is offline
Corolla- Tilt steering problem
I have a 2001 Toyota Corolla, The japanese version. It has the tilt feature on the steering wheel which allows the driver to adjust the steering wheel up and down. Recently i have noticed that the lever that locks the wheel in place after it is adjusted it not holding it securely. So when i am driving with the wheel adjusted up, it is dropping down unexpectedly. Whats going on there?
Old 08-14-2009, 10:47 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Corolla- Tilt steering problem
Probably the bolt(s) holding the locking mechanism has loosened and need to be tightened.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-16-2009, 10:47 PM
hey bro i took off the bolt assembly and checked it out and you were right...the screw needed tightening. Everything is working good now.....Can you believe i went to a mechanic and he told me i needed a new steering column. Thank god for these forums. Thanks man
