Old 08-12-2009, 03:29 PM
khadma khadma is offline
Trannsmission fluid on garage floor!
Yesterday I pulled our 1999 Taurus in to the garage to check the front brake wear.
I noticed that there was oil on the floor, and it turned out to be transmission fluid.
We just bought this car about 3 weeks ago (only 63,000 miles) and this is the first time I seen the leak (I did not notice any leaks when I change the engine oil last week).
The previous owner did not drive the car on longer drives like we do.
I noticed the LOWER transmission oil cooler line (at the transmission end)
has oil at the connection point (to transmission).
Is this a common problem?
Is the seal common to breakdown?
1999 Taurus
1995 Windstar
1996 Bronco
2005 Escape
2002 F150
2007 Explorer
Old 08-12-2009, 06:22 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Trannsmission fluid on garage floor!
They are a common failure point. We usually replace the screw kin part of the connector. There is an "o" ring in there that will start leaking. Good luck
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
