Old 08-12-2009, 12:16 PM
MSRsMom MSRsMom is offline
2000 power lock switches not working
Hi I have a 2000 Dodge Caravan. The power lock switches are no longer working (both driver and front passenger). They worked fine the last time I drove the vehicle and both switches stopped working at the same time. The power locks themselves still function with the remote and still lock when speed reaches 25km. Just the actual switches on the doors are not functioning. Any ideas??
Thanks
Old 08-12-2009, 02:58 PM
cbwilsha cbwilsha is offline
Re: 2000 power lock switches not working
Easy fix. Look in the Integrated Power Module (fancy name for fuse block) under the hood on the Drivers side. The top is held on by two clips. In the lower left (as you are looking at the block) is a 10 Amp fuse marked IOD. Pull that fuse for a few minutes, and replace. Your locks will now work! The inside of the top shows the location of all the fuses and relays so you can look there for the location if you have trouble finding it. Let us know if all okay.
C.B.
Old 08-13-2009, 04:10 PM
Did it work?
C.B.
Old 08-21-2009, 09:47 AM
Been over a week now, MSRsMom, did my suggestion work for you?
C.B.
Old 05-02-2013, 05:03 PM
anelson1995 anelson1995 is offline
Don't know about anybody else but I had this problem on my 05 Caravan and it worked like a champ. Thanks.
Old 05-02-2013, 06:41 PM
I'm glad you found this nearly 4 year old thread helpful.
C.B.
