1997 s-15/sonoma 4.3 vortec v6 been setting in a garage for 2 years run great when parked, replaced with a new battery started, had a bad miss, replaced plugs plug wires complete dist. dist.cap,module rotor,,, same miss CAN OBII random/multiple cylinder misfire P0300 cant figure out please HELP !!! Banging head. PS has only 33000 miles
Re: HELP!!! misssss cant fix
Need alittle more information. What is your VIN Number.
the vin #1gtcs14x8v8521559
Lets rule out the basic’s.
1. Re-check the plug wire firing order. 2. Double check for vacuum leaks 3. Fuel Pressure reading. Key on 61-65 psi. Key off, pressure leak down not lower then 55psi after 20 minuutes. 4. Check EGR valve for carbon chunks. Re-install with new gasket. Report back your findings. |
