Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-11-2009, 09:10 PM
ropergilson ropergilson is offline
96 Ram 2500 ABS
The ABS light comes on and stays on when you start the truck, but goes out as soon as you put it in gear. Sometimes it wont go out until you drive a few miles. Failing sensor?
Old 08-12-2009, 10:34 PM
Re: 96 Ram 2500 ABS
Its also a 4 wheel ABS
Old 08-13-2009, 01:27 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 96 Ram 2500 ABS
Yup, check the wiring to the wheel sensors. It'll be an electrical wire going to the front hubs if your speedo is working ok.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
