Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-11-2009, 03:51 PM
oldkckr41's Avatar
oldkckr41 oldkckr41 is offline
PCM 1 fuse
2004 tahoe I keep blowing pcm 1 fuses I would like to think it isn't the fuel pump. only code is a PO141 Ox sensor bank n1 sensor 2 could this blow the pcm 1 fuse it doesn't blow immediately
Old 08-11-2009, 03:59 PM
TheBobsHere's Avatar
TheBobsHere TheBobsHere is offline
Re: PCM 1 fuse
Any sensor or wire with a dead short can blow PCM fuses or trip breakers. A bad PCM could to.
Old 08-11-2009, 05:08 PM
ronaldk's Avatar
ronaldk ronaldk is offline
Re: PCM 1 fuse
I have to agree with bob, its a short. the pcm 1 fuse does power 02s so pcm is coding 02. poss wire there has pulled out or burned off of 02. let us know good luck
Old 08-11-2009, 07:43 PM
oldkckr41's Avatar
Re: PCM 1 fuse
Thanks I will keep you posted
Old 08-11-2009, 09:26 PM
oldkckr41's Avatar
Re: PCM 1 fuse
I found it The wire harness that goes to the left side oxygen sensor fell out of its hold down and into the drive shaft severing two wires in half. now to find a harness I don't think it is a good Idea to try to mind thanks agian for the help.
Old 08-11-2009, 10:00 PM
j cAT j cAT is offline
Re: PCM 1 fuse
if the wire in the vehicle harness is broken splice a new wire to replace...use solder and heat shrink insulation...
the O2 sensor wires attached to the o2 sensor are not to be repaired..though..
Old 08-11-2009, 10:57 PM
ronaldk's Avatar
Re: PCM 1 fuse
Glad it worked out for you thanks for posting back.
Old 08-12-2009, 09:39 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: PCM 1 fuse
What engine?
Best to get a wiring diagram for you engine and VCM and check all circuits that are on that fuse.
How often does it blow fuse?
Check all wiring real close and run a amp draw on fuel pump and other circuits on that fuse.
Some times you have to unplug one circuit at a time to find which one.
Let us know how it goes.
MT
Old 08-13-2009, 05:28 PM
oldkckr41's Avatar
Thumbs up Re: PCM 1 fuse
I replaced the missing section of wire with some 18 Ga., soldered and shrink tubed the sections ,replaced the wires back in the harness, taped and wire tied it back in place. The code went away, and seems to be working. Thanks again.
Old 08-13-2009, 06:03 PM
Re: PCM 1 fuse
thats better than any repair shop would do...good luck..
