Old 08-11-2009, 08:08 AM
gphelmick gphelmick is offline
02 cavalier
when should the electric cooling fan turn on? 02 cavalier 2.2 engine. the temp has gotten up to about 200 and didn't come on
Old 08-13-2009, 03:30 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 02 cavalier
222 degrees turn on, 204 turn off... or something very close to those numbers. I reprogrammed my PCM for 210 turn on/190 turn off, and I don't remember for sure what it was at stock.
Driving, mine runs at 188 in "clean air", will get up to 196 "drafting" .
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
