Old 08-11-2009, 07:28 AM
spalen spalen is offline
Sport Shift
I have a 1990 Honda Accord that's stuck in 'Sport Shift' mode. We have replaced the computer and a sensor in the front part of the motor and neither one has removed the 'Sport Shift mode. Any suggestions?
Old 08-12-2009, 09:01 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Sport Shift
Isn't there a selector switch in the console or on the shifter?
Think I woulda started there if so...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 08-12-2009, 09:30 AM
Re: Sport Shift
The switch didn't make a difference even after we replaced that. Could it be in the electrical somewhere?
Old 08-13-2009, 11:47 PM
mpumas mpumas is offline
Re: Sport Shift
Is the speedometer working OK?
Old 08-14-2009, 06:36 AM
Re: Sport Shift
Yes, the speedometer works fine. The 'S' light stays on and it's won't come out of the Sport Shift.
Old 09-21-2009, 12:56 PM
tonysilvachico tonysilvachico is offline
Re: Sport Shift
The sport shift light is also a code flasher.....you need to use a jumper wire on the service plug...to retrieve the code. The service plug is a two pin female plug located underneath the glove box or it will be dangling down behind the passenger side kick panel. ONE LONG FLASH=10
SHORT FLASHES=1
Old 09-21-2009, 01:00 PM
Re: Sport Shift
Either way that is the reason why the light is staying on...to let you know a sensor is defective or a sensor is detecting a problem get the light to flash...find the code...repair the problem.
