Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 08-11-2009, 06:00 AM
marcorell7 marcorell7 is offline
backfire
Hi, here is my problem, 87 Ford Bronco ii is backfiring every time that I started untill it gets to normal temp. Please help.
Old 08-13-2009, 02:43 PM
rhandwor rhandwor is offline
Re: backfire
Unplug the sprout and check base timing. Then when it plugged in make sure the computer is advancing the timing.
A break in a plug wire will cause a back fire but this would occur after its warm.
How bad is the back fire?
Old 08-14-2009, 05:53 AM
Re: backfire
the backfire is pretty bad untill the car get to normal temp .
Old 08-19-2009, 09:55 PM
ronaldk's Avatar
ronaldk ronaldk is offline
Re: backfire
Hi, heres my problem I dont know your eng I dont know if FI or not, but if I were to guess could be vac leak causing lean when cold not as noticed when warm , could be temp sensor messing with brain when cold, could be EGR valve. Are there codes?obd1 still can code map sensor etc. may be this helped dont know
