| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
420a arp Head stud torque
I don't know if any of you guys have searched for the torque specs for these damn arp head studs, but the numbers are all over the place. One guys said he didn't use a three step process, just went from hand tight to 80 ft-lbs and he's went 10,000 miles without problems- i find that hard to believe.
So, what have you guys torqued yours down to? I have the arps head stud kit along with a cometic head gasket. By the way, i have the AEM piggy back (easy to tune and a great buy!) which means i can't go over 26 psi of boost without an upgraded on-board map sensor. So that will be the most i will ever run. I read somewhere that the amount of boost can determine how tight you should have the bolts. Imput? |
Re: 420a arp Head stud torque
I believe I torqued mine down to 75lbs and had trouble with the head spraying coolant and high boost. Retorqued them to 85lbs and haven't had trouble since. I dont remember what specs are but 85 should be plenty. I have heard of people running over 90 so I think you will be ok.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Donno if there is any difference between the 4g63 and 420a for head stud specs but I did mine in three steps. 30-60-90...
-Brian
O yea I forgot to add that. Use the torque sequence in the shop manual. I believe they do a 3 step process so follow that and just torque them to 85 or 90 for the final step. Don't use the torque specs for the stock head bolts
Yeah i am definitly going to use the manufacturers pattern and sequence. And just to be safe i'll torque them to 90. Thanks guys!
