Old 08-10-2009, 08:04 PM
js63 js63 is offline
Brake pedal fade
05 Town and Country. Replaced front and rear brakes and master cyl. Brake pedal fades at a stop, pedal goes to floor. Was doing this before these parts were replaced. Vehicle does not have ABS. Any help would be great.
Old 08-11-2009, 11:04 AM
manlystanley manlystanley is offline
Re: Brake pedal fade
When you say replaced front/rear brakes, does that include the calipers/ wheel cylinders? Do you have any traces of brake fluid leaking out? How did you bleed the brakes; using the push brake pedal technique, our use a hand held tool?
1995 Plymoth Grand Voyager; 1998 Volvo S90, 2000 Ford Ranger, 2002 Dodge Grand Caravan.
Old 08-11-2009, 07:24 PM
Replaced shoes and pads and master cyl. No visible leaks were found. Bench bled master cyl. before installing on vehicle and then bled on vehicle at master cyl. Problem was there before I ever touched vehicle
Old 08-12-2009, 05:39 AM
I think that you should bleed the entire system. You can press the brakes and then loosen up the bleed screws at the wheel cylinder/caliper. I have had problems in the past getting a good bleed, so jacking up the rear end and letting it sit for a while (letting an air bubble raise up) seemed to help.
I've seen hand-held bleed tools in the auto parts store and have thought of buying one. My vans have always been hard to bleed just using the pump brake petal approach.
You might want to flush the brake fluid at this time. I do on my cars/trucks every 5-7 years. A 2005 is a bit early, but then again you've got everything opened up...
Best regards,
Stan
