Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 08-10-2009, 07:52 PM
jamesbaugher jamesbaugher is offline
light problems
I have a 84 fiero parking lights and dash lights not working. I changed the fuse and when switch is turned on it blows the fuse. If you leave the switch on then put in a fuse everything works but when switch is shut off it blows the fuse. so I replaced the switch with a brand new one. and I still have the same problem. can anyone help me? thanks
Old 08-13-2009, 12:49 AM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: light problems
There may be a positive wire rubbing against something metal, and the insulation has rubbed through. Based on what you've told me (the problem can happen turning the switch both on OR off) the bad spot is probably between the fuse box and the switch.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 09-06-2009, 04:24 PM
Blue Bowtie's Avatar
Registered Offender
Re: light problems
Have you checked the isolation realy for the headlight motors? Common problem.
