Old 08-10-2009, 06:54 PM
sparko2424 sparko2424 is offline
help 96 lumina
my new fuel pump does not turn on. i instaled a new fuel pump and relay and checked the fuel injectors all read 12.3 ohms. the engine turnsover and i can jump the fuel pump and hear it running. the car at times run sometimes but it hasn't in 3 days. any help????????????:scre wy:
Old 08-11-2009, 01:02 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Re: help 96 lumina
Did you replace just the pump, or the whole assembly? Why did you replace it?
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 08-27-2009, 03:37 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: help 96 lumina
lumina have pump module assembly
cannot replace pump only
check for power and ground at module connector under car next to tank driver side
if one missing then bad relay or bad ground or bad ign switch or bad ECM or bad fuse for ECM
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
