Old 08-10-2009, 07:46 PM
timmmm timmmm is offline
02 grand prix gt wont go over 3500-3600 rpm
02 grand prix gt 3.8 engine will not go over 3500-3600 rpm. barely gets out of first gear will not get out of second max speed 45-48 mph. passing gear will not engage. changed fuel filter. checked converter with temp gun. temp close front and back. any ideas? no codes or lights on dash.
Old 08-10-2009, 10:43 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 02 grand prix gt wont go over 3500-3600 rpm
Clogged cat would be the most common reason for this problem. Remove & replace the cat, or install a cat delete (bypass) & see how the engine runs!
Old 08-11-2009, 07:42 AM
BNaylor's Avatar
BNaylor BNaylor is offline
How many miles are on this GP? See the link below located at our Tips & Maintenance subforum if you have under 120K miles and since it is a '01-'02 model. The GM dealership may cover the diagnostics and replacement of the CAT for free.
http://www.automotiveforums.com/vbul...d.php?t=681283
And welcome to AF.
Timeslip 08/12/06
AF Community Guidelines
Old 08-14-2009, 07:25 PM
And welcome to AF.
thanks a lot. called our local dealer and they replaced it for free. thanks
