Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-10-2009, 07:30 PM   #1
jesselv
Is a radiator flush on an older Rodeo OK?
I've been warned that a trans flush on an older transmission could cause problems. Does the same hold true for a coolant flush and fill.? Is it possible this process would loosen built up gunk and clog the system.? Specifically I'm thinking it might cause a problem with the thermostat. Any help would be appreciated.
jesselv is offline   Reply With Quote
Old 08-11-2009, 11:21 PM   #2
FL 3.2L
Re: Is a radiator flush on an older Rodeo OK?
You should change the thermostat with every flush and refill. Which year is your truck? If it is a first gen with the V6 it is very easy to swap the thermostat.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
FL 3.2L is offline   Reply With Quote
