Old 08-10-2009, 03:16 PM
cgirlz71 cgirlz71 is offline
Drivers Seat Soaked
Sometimes when it rains my drivers seat will be soaked, or will be leaking. From half way from the window down towards the windshield, also by the controls of my electric sunroof... The headcover was removed and thought it was the sunroof leaking so it was sealed shut... the problem has reoccured... what do you think it could be and how would i go about fixing the problem?
Old 08-10-2009, 04:04 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Drivers Seat Soaked
Remove the trim around the drivers door area and get in the car and close the door. Have someone spray that half of the car with a garden hose until you get water coming in and just follow it up to where it starts coming inside.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
