Old 08-10-2009, 11:00 AM
Rookie#1 Rookie#1 is offline
Cool 1995 Dodge Caravan
When I turn the ignition key to start position the speedometer and tack peg out for a instant and vehicle won't start. There's a click when key is turned on which I assume is the fuel pump. Any body have similar probems? In the recent past we had a problem with the body control module. Removed the fuse and it cleared that probem. Help....
Old 08-10-2009, 01:16 PM
Re: 2005 Dodge Caravan
CORRECTION ON CARAVAN YEAR---Don't work thinking about another problem while working on one.
Old 08-10-2009, 01:39 PM
nixonrules nixonrules is offline
Re: 1995 Dodge Caravan
If you wiggle the key in the "start" position, does that change anything? Thinking maybe an ignition switch is to blame.
Old 08-10-2009, 09:26 PM
Angry Re: 1995 Dodge Caravan
Thanks for the response Houston. Key wiggle didn't get her done.
Old 08-11-2009, 11:11 AM
manlystanley manlystanley is offline
*If it's safe* , try going beneath the van. See if the click is from the starter solenoid, fuel pump or what. See if you've got 12 volts going to it. The starter should have two lines, a switched 12v to the solenoid, and 12V direct from the battery to power the starter. The ground comes from the chassis.
If it's just solenoid clicking, try taking the starter off and hot wiring it to the battery. It might tell you something.
Best Regards,
Stan
1995 Plymoth Grand Voyager; 1998 Volvo S90, 2000 Ford Ranger, 2002 Dodge Grand Caravan.
