Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-10-2009, 12:25 AM
eclipse78952's Avatar
eclipse78952 eclipse78952 is offline
stock valve springs/retainers - 420a
How many pounds safely does everyone think i can run with the stock springs and retianers? I have a built block, just don't want to buy them unless i really need them.
Old 08-10-2009, 07:15 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: stock valve springs/retainers - 420a
How high do you plan on reving the motor? I am running a stock head and have taken it up t0 25psi with no problems. But only to about 6.5k, if you plan on reving it much higher or running over 30psi of boost I would upgrade them.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-10-2009, 10:29 AM
maybe 7000 at most, but i could keep it to 6500 if i have to. But when you buy new springs, all you really preventing is valve floating right? So if i don't rev it real high like a dumbass i should be fine. What about putting cams in it in the future? Will they be needed then?
Old 08-11-2009, 09:48 AM
Holset powered 420a
If you put cams in it then I would change them out. You may be able to get away with it if your where NA. I think the main issue is that people want to rev higher after upgrading and the stock springs can't keep up. Stock springs are around 45lbs if I remember right. So add 25psi of boost and you now only have half of that spring pressure closing the intake valves
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-11-2009, 10:19 AM
Good point. Thanks.
Old 08-11-2009, 12:05 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Stock springs are made to hold all the way to redline. However, time takes its toll on them making them weaker. The only time you really NEED better springs are with mild cams. Even "stage 1" (for lack of a better term) can still use stock springs with no problems as long as they're in good shape. My springs are upgrade since I have "stage 2" cams and a fully built head. I knew it was going to be seeing boost, so did it all.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-11-2009, 09:21 PM
Im just going to use the stock ones for now, and when time comes where i want to buy the stage 3 crower cams, i will just do everything.
