Go Back   Automotive Forums Car Chat > Ford > Freestyle
Old 08-09-2009, 08:55 PM
garrytoao garrytoao is offline
rear breaks
have a 05 limited awd the rear pads need replaced. is this a do it yourself job if i get the special tool needed? ford wants to much and the tool is twenty bucks. this cars eats the pads because of the design flaw.???????????????
Old 09-16-2009, 08:28 PM
Dan_J Dan_J is offline
Re: rear breaks
I changed the read pads on my 05. Don't remember needing a special tool. Good luck.
Old 09-19-2009, 09:05 PM
rhandwor rhandwor is offline
Re: rear breaks
http://www.sjdiscounttools.com/lis41000.htm
Some newer Fords need a left hand tool. My OTC I can just reverse my ratchet. I've noticed them slightly cheaper on http://www.ebay.com/
Old 10-23-2009, 06:28 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Re: rear breaks
the rght rear caliper is reverse threaded. left to tight (or compress) the piston. the cars for certain model years had extended brake coverage because the rear pads got wet at an assembly plant. the coverage is only good for a certain year, and upto 36k. instead of the normal 12k for brakes. but yes, in general, those tiny pads tend to wear fast, and the rotors don't have much room to machine.
