Old 08-09-2009, 05:00 PM
proscroby's Avatar
proscroby proscroby is offline
Window glass
I have noticed that when it rains, the drops on the glass in my 98 GP are nor removed when I lower the glass. We had a fairly heavy downpour last night and it was impossible to see on either side. I had to stop and use a chamois to dry the glass. Is there an easy cure for this?
Old 08-10-2009, 01:24 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Window glass
windex all your windows twice and the put 2 coats of rainx on them. With rainx, it can be a dounpour and you'll be driving at 55mph and the rain will fly right off. You wont even need your wipers.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-10-2009, 02:24 PM
proscroby's Avatar
Re: Window glass
I guess I was not clear in posing my question. My problem is with the glass in the doors. When it rains and I lower the glass, it does not remove the water and I cannot use the side mirrors.
Old 08-11-2009, 09:02 PM
tblake's Avatar
In God We Trust
Re: Window glass
I guess I do not understand your question.
Old 08-11-2009, 11:01 PM
proscroby's Avatar
Re: Window glass
After it rains and there is water on the windows, when I lower the glass it does not remove any of the water and I cannot see outside. It looks as if the piece of plastic/felt which is part of the door does not touch the glass.
Old 08-11-2009, 11:07 PM
doctorhrdware doctorhrdware is offline
Re: Window glass
As Tim suggested clean the door windows 2x with windex and then treat with rainx, and that will fix your problem with not being able to see out the window.
Old 08-12-2009, 01:29 AM
tblake's Avatar
In God We Trust
Re: Window glass
Yeah, the felt/weatherstripping is not meant to wipe rain off your windows.
Old 08-12-2009, 04:02 AM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Window glass
are you saying that there is moisture building up on the inside of your windows? you might wanna check the heater core...
Old 08-12-2009, 05:41 PM
proscroby's Avatar
Re: Window glass
Thanks for the tips. I will get some Rain-X and apply it along with the windex as TBlake suggested.
Old 08-12-2009, 08:17 PM
tblake's Avatar
In God We Trust
Re: Window glass
Good idea! That stuff works wonders. (wax for your windows)
