Old 08-09-2009, 08:27 AM
12Ounce 12Ounce is offline
Crankshaft sensor ... engine stumbling. 1999 3.8
1999 3.8 engine 261k miles. Crankshaft sensor failure.
Six months ago the engine began "stumbling" very infrequently. Over time it happened more and more. Finally the engine did not want to be loaded up ... did not want to accelerate or climb hills. But this was sometimes not the case ... sometimes, the engine would run fine for brief periods. Never was cranking or idling an issue.
Even tho the stumbling became quite severe ... there never was an engine code. At least, there was no CEL.
Because of a recent experience with S's Escape:
http://www.automotiveforums.com/vbul...d.php?t=957259
... I went for the crankshaft sensor early. DID THE TRICK! All seems to be OK now. Hope this helps someone.
Old 08-09-2009, 10:45 AM
Lbert Lbert is offline
Re: Crankshaft sensor ... engine stumbling. 1999 3.8
Thank you for sharing the experience.
Old 08-10-2009, 08:29 PM
Well, I posted the "good news" too soon!
The new crankshaft sensor did make things much, much better ... but as I later took a long ride, I found the old "infrequent stumble" was still with me. It was as if I had turned the calendar back 6 months! ... and still no CEL! So disappointing to have the stumble, and with no CEL to help diagnose. My AutoZone folks won't even walk out the door with the scanner unless the CEL lamp is lit!
Then I had an idea ... If a code were "induced", would it cause other faults to be reported? I removed and plugged the control hose to the EGR valve, and drove 10 miles or so until the CEL turned on ... then drove straight to AutoZone to get the codes read. Of course, the EGR codes were there ... and so was misfire codes for cyls 2 and 6! BINGO! Now, I knew the center coil ( for sibling cyls 2 and cyls 6) of the ignition pack was faulting! Even tho the coils read closely when checked with ohmmeter ... and I could see no surface tracking or cracks ... the 50k mile-old coil was replaced.
NOW! I have driven a number of miles ... gunned it several times. Seems OK!
Old 08-10-2009, 08:41 PM
wiswind wiswind is offline
Seems those coils are right up there on the fail list.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
