Old 08-09-2009, 07:36 AM
chevy666 chevy666 is offline
Bad lifters,adjusting valves....
I have a stock 350,1989 chevy pickup 2500 4x4. and i´ve had some issues with my valves when trying to adjust them. Now im guessing that my lifters are bad, when adjusting the valves and pushrod, tightening them until the pushrod stops floating between my fingers and so on. But everytime i tried it i seem to be tightening them to much so im guessing that my lifters are worn, the pushrod goes down to far becouse the spring in the lifter is to worn... So is anyway to adjust the valves bestides the method thats described in the books? The one i tried out? Tried adjusting the valves with the car running but im having a hard time hearing when the start clattering....Plus all the oil that keeps pumping out on the headers
Thanks for all the help!
Old 08-09-2009, 09:23 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Bad lifters,adjusting valves....
Make sure you have the adjustable lifters.
Some time you run into solid lifter on a hot rod engine.
When adjusting running.
Losen the up wtill you feel or hear them click a little or push rod spin free.
The tighten down slow.
Give the a 1/4 at a time and wait a while for adjustment the adjust down to 1/2 or 3/4 turn down and wait and see if the re adjust.
If not try the repair book engine not run procedure.
MT
Old 08-09-2009, 09:43 AM
777stickman 777stickman is offline
http://www.classiccarauto.com/impala...t_valves.shtml
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 08-09-2009, 09:44 AM
ronaldk's Avatar
ronaldk ronaldk is offline
The repair book procedure is for all new lifters , once pumped up ( quote from friend owns eng rebulld shop) the messy old school way the way to go as you discribe. Stickman as I was typing you placed above post I went to site VERY INTERESTING once valve on 350 adj wrong real pain but you posted site looks great I have 93 caddy 350 I wanted to do (someone did wrong before I bought #3 wasnt even fireing was so tight) did that one so I could drive will try your way.
Old 08-31-2009, 09:06 PM
rovertec1958 rovertec1958 is offline
Is this occuring with all the rocker arms , or just a chosen few . the rocker studs are pressed into the heads and the may be pulling out of the head
bosses increasing the clearance .
