Old 08-09-2009, 01:33 AM
andy_99w_csh andy_99w_csh is offline
02 2.2 cavelier turbo question
i am buying a turbo kit soon, i think it comes with everything that i need to hook it up to the car can i use stock injectors and compensate with a fule pressure regulator?however i am running a stock fuel pump,any opinions?would it be safe running it with a stock ecu or should i have it tuned?if i have to get it tuned is there somewhere i have to send it or get a handheld tuner,and where?if i have to get it tuned is it safe to run my car on the lowest boost setting?
thank you
Old 08-10-2009, 03:47 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 02 2.2 cavelier turbo question
Duplicate post, lets all respond to the one in the "performance" forum...
Don't double post...
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Last edited by J-Ri; 08-10-2009 at 04:08 PM. Reason: Saw the other post after I responded to this one.
