| Performance Anything you ever wanted to know about boosting the performance of your Cavalier. |
02 2.2 cavelier turbo question
i am buying a turbo kit soon, i think it comes with everything that i need to hook it up to the car can i use stock injectors and compensate with a fule pressure regulator?however i am running a stock fuel pump,any opinions?would it be safe running it with a stock ecu or should i have it tuned?if i have to get it tuned is there somewhere i have to send it or get a handheld tuner,and where?if i have to get it tuned is it safe to run my car on the lowest boost setting?
thank you |
Re: 02 2.2 cavelier turbo question
Stock fuel pump is just fine. You may loose a pound or two of pressure at WOT (I've never checked mine) , but that would be compensated for when you tune it, which brings us to your next question, you must tune it. I have HPTuners which is very good. There's at least one other, but HPT is what everyone seemed to reccomend when I was asking about boost a few months ago. www.hptuners.com There are no places that you can send your PCM to have it reflashed, your tune will be specific to your car which means whoever tunes it needs access to your car. I have heard of a place that "tunes" it by looking at your LTFT numbers and guessing at what the fuel tables should look like. I could write pages about why not to do that, but won't, just don't do it ![]() If you have someone else tune it, keep the wastegate open while you drive it there. I'm not at all familiar with turbos, but it should be fairly easy to do. If you tune it yourself, I can give you a bit more help, just let me know what you decide.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
Welcome to a world of problems with boosting a cavalier...
Please don't PM me with your J-body Issues. Post appropriately in the forums, and I will toss my opinion in your thread if I have anything to help. - Thanks! 2006 Chevrolet Trailblazer 2010 Glastron GT 205XL |
