Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-07-2009, 09:38 PM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
New owner: 99 suburban LT HELP!
I found a 1999 suburban 1/2 ton, LT, 4wd. 113,000 miles on the clock, no engine tranny probs. has a bad rear diff, and transfer case needs rebuilt. He bought it at an auction and doesnt want to fix it (honest!). He owns a body/collision shop. He said that there are no collision damage and that everything is fine. He gave the interior an 8/10.
He said he would take 1000 for it, so I said hell yeah. Thing is I have to drive 2 hours to get it this sunday and he said it will get me home but he restated the rear end issue. He is driving 70 miles to make my trip shorter.
Im kinda freaking out because I dont know about these burbs. Is there something I should know about these? I already found a guy selling a rear axle from a 89-99 1/2 ton silverado/tahoe/suburban said it will fit. He wants 300 for the entire back diff with drums and all.
WHat kind of transfer case should I start searching for or can these be rebuilt? I have a good feeling about it, its just so cheap for a low mileage 1999 LT with leather
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
Old 08-08-2009, 10:18 AM
ronaldk's Avatar
ronaldk ronaldk is offline
Re: New owner: 99 suburban LT HELP!
$300 v.good price on rear.I would open making sure alls well inside no play etc.then replace fluids. the TC can be rebuilt. but because bad I cant even suggest you bring tools to remove rear drive shaft put in 4wheel and lemp home using front end to power you home.Thats real low miles for all that wear!!!??? Hope works for you
Old 08-08-2009, 11:00 AM
Im trying to get the rear end for 200 atm. Im going in the morning to get the burban. And I just so happened to find the rear end 20 minutes from the suburban.
I will post some pics and vehicle condition to get started on the process.
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
Old 08-08-2009, 05:08 PM
ronaldk's Avatar
my friend owns junk yard and that rear yard to yard there charge to each other usually 500 make sure gear ratio same as truck your buying theres tag or stamp on rear i am not sure on that year.
Old 08-08-2009, 05:48 PM
Ok thanks !!
Will double check that. Pretty cool to find a part I need 20 minutes after taking delivery of a vehicle. I wanno go over it so bad I cant wait. I am a die hard DIY WIll check the tags on axle before going to pick up the other axle but I think owner said it was definitely a 3.73
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
Old 08-08-2009, 05:53 PM
PS What axle codes are 3.73? The donor vehicle was a 96 yukon 4wd 1/2 ton, axle going on a 99 burb 4wd 1/2 ton
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
Old 08-08-2009, 08:06 PM
ronaldk's Avatar
ya I wish I remembered . But if you turn axe at wheel once your yoke will turn 3 and 3/4 turns(apx) close enough to know you have correct one. also that I was told was the rare one 3.73 (cause thats the one I needed to fix wifes 90 subr years back. my freind at junk yard would have that info but hes closed until monday maybe someone else here reading this post may have that info, unfortunatly I dont have that sorry.Turning wheel and counting drive shaft will work though.
