Go Back   Automotive Forums Car Chat > Racing > Non Specific
Old 08-07-2009, 05:45 PM
din365 din365 is offline
454 big block GMC sierra vs 2.0L 420hp mitsubishi eclipse
Ok, I was having a little discussion with a friend of friend of mine about his mitsubishi, and my brother's 454 big block GM.
But, seeing how I need an unbiased view on this, and with the tale of the tape(both engines have obviously been redone), which one would most likely win in a drage race and a plain old straight up race?
Car 1:
1991 mitsubishi eclipse GSX-420 AWHP, roughly 300LBS of torque. 15 grand worth of work done to get it there.
Car 2:
1993 GMC sierra 1500 4x4-500HP and 400 lbs or torque. 4 grand worth of work on the engine(engine was bought for 600$, and reworked)
I just thought it would be an interesting racing question to some racing enteusiest, and give an unbiased perspective of things.
thanks.
Old 08-07-2009, 06:24 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: 454 big block GMC sierra vs 2.0L 420hp mitsubishi eclipse
1. How does the GSX have that much HP but next to no torque? Your numbers are way off. That car produces more than that stock.
2. Despite the numbers, the GSX has traction, the truck doesn't. The GSX is also lighter than the truck.
3. Now we have gearing. Who's is better for drag racing?
4. Lastly, who's the better driver?
There are too many variables to say for sure but my money is on the GSX.
Old 08-08-2009, 01:33 AM
sorry. My friend corrected me on this little fact. it is 300 lbs of torque. I fixed that in the original post just now.
Old 08-08-2009, 02:01 AM
TheBobsHere's Avatar
TheBobsHere TheBobsHere is offline
The Eclipse is lighter and more aerodynamic and was obviously built to race, I'd say it'd win on pavement. The truck is heavy and built like a brick so it would win off road. But, I'd like to see the Eclipse try in the mud, that would be fun. In the end it would take an actual race to find out for real, It all comes down to power to weight ratios, my money's on the Mitsu.
Old 08-08-2009, 12:08 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Eclipse, if it really does make 420 wheel horsepower that means it's making roughly 500hp at the crank. So the Mitsu and the Truck are making similar power, the Mitsu has the benefit of carrying about 2,000lbs less weight and has AWD to help with traction.
Just based on those facts, the Mitsu would win.
The only place the Truck maybe able to hurt it is if it's got large tires, and is geared up, having enough traction out back it might be able to hang with the Mitsu till about 60mph. Despite the weight differences, Trucks can still move out... Torque is your friend. Big Block Chevy's make good torque way low in the rev range, basically off idle...
Would be interesting to see nonetheless.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 08-08-2009, 02:41 PM
The truck is 4X4 and heavy so off the line traction wouldn't be a problem. With really big gears and nitrous (and Jesus sitting in the passenger seat) maybe, maybe it would win. But that would be a miracle. The problem with gears big enough to pull 5500lbs off the line competitively is the engine would tach out before the end of the track and the Eclipse would eclipse the truck. Now, trailer a boat on the back of the eclipse and were talking an even race (and something I would just have to see).
Now, enough with the schoolboy racing, set it up and post the video.
Old 08-08-2009, 02:58 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
If those number are spot on the Ecplise would seriously wax him bad and it would only get worse as the race progressed.
BTW, how did it take your friend $15k to make 500hp in an Eclipse? Or is that what he has invested in the car as a whole with other (non-poweradding mods) mods?
Old 08-08-2009, 04:38 PM
that's all in mods.
here's the list right here
Full Turbo Back Exhaust including Down and Test pipe.
Turbo Manifold
Hot Side
Intake
650 Injectors
fp Red Turbo
FMIC
MAF
Stage 2 Clutch
Evo3 o2 Housing
New oil Lines
Fuel Pump
272 shafts
Rubber around 4 Including Rims
All my strut bars/stabalizing bars
Brakes/pads around all 4
Coil Over Suspension work
Greddy BOV
Pistons
Rod
Bearing
Head Studs
AMS Tune
Boost Controller
Turbo Timer
Weight Reduction (nothing in trunk, replacing hood, and dropping backseats)
And for the GMC, I don't have an exact list, except for the intake being redone for sure.
That won't happen untill at least next year, because both vehicles are still being built. However,when the open drag racing event happens at the provost Airport next year and if he does decide to enter it, and if it's back together by then, I'll be sure to at least get some video on it racing.
Old 08-08-2009, 05:07 PM
The truck will be left like a girlfriend with herpes.
Old 08-09-2009, 12:35 AM
MZR_47's Avatar
MZR_47 MZR_47 is offline
Send a message via MSN to MZR_47
The truck is going to lose in this case... But I am also curious on that $15,000 pricetag. That seems to be a bit much to me, but I could be wrong. Even on cars that are expensive to mod they can hit 500hp for under 10k.
MOAR BOOST
Silencer Delete | SPT Catback | Megan Racing DP | TEIN Flex Coilovers | Front and Rear Sway Bars | DBA Rotors | TurboXS UTEC | 18 psi
Old 08-09-2009, 02:18 AM
CassiesMan's Avatar
CassiesMan CassiesMan is offline
AF Vendor
Send a message via AIM to CassiesMan
Have the truck give the car a two car length advantage. When you line up and the flagger raises his arms, launch the truck hard in the rear quarter panel of the Eclipse hard. Truck wins.
2006 Redline Red Nissan 350Z Base
K&N|Falken
I am just that JDM tight, yo.
Old 08-09-2009, 11:43 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Fail that it took him 15000$ to make that much power. I imagine most of that is in labor, which shouldn't count. So realistically he's only got maybe 6000 and he still coulda spent that money wayyyyyy better.
Also on the gmc. 4wd isn't going to help, like at all. Providing he uses it, he can't switch back to 2wd when he gets traction and that 4wd will cause excessive drag on the powertrain. It won't assist whatsoever.
The eclipse will win by more than 1 second. If it doesn't make him sell the car for 200$ to me and I'll treat it right.
Don't act like you don't love it.
503/2000
