Go Back   Automotive Forums Car Chat > Chevrolet > Corsica
Old 08-07-2009, 04:23 PM
racerxpl racerxpl is offline
geez. oil pressure absent
So we overheated and destroyed the head gasket. Took it apart, replaced gaskets, put it all back together. Drained the oil figuring that there was a bit of stuff in it with all the cleaning of the block to put the new gaskets on. Put new oil in it and started it up. Oil light doesn't turn off and there is a bit of a ticking sound. Any one have any ideas? I did check the oil pressure sending unit plug and wiring and couldn't find anything wrong with it. Do I need to replace the oil pump now? It was fine before.
Old 08-07-2009, 07:23 PM
rhandwor rhandwor is offline
Re: geez. oil pressure absent
Use a manual gage and verify oil pressure. The link is a picture of a test gage. http://www.autopart.com/tools/toolsmain/tool/T_2001.htm
If the pressure is actually low I would suggest cleaning the strainer its probably covered with trash.
Old 08-07-2009, 08:40 PM
Thanks I could use that on my Mazda too. We'll drop the oil pan and check that out. I guess we can probably check the condition of the pump at the same time......
