Old 08-07-2009, 02:39 PM
SsHaDyGt SsHaDyGt is offline
Need torque specs for LIM and SC
Hi all,
I'm installing an SS intercooler and a ported LIM. I got a new LIM gasket and coolant elbows.
My question is, what are the torque specs/ tightening procedure for the LIM and the SC?
Also, if anyone has a link to instructions on replacing the LIM gasket, that would be helpful.
98 GTP l67
Thanks
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 08-07-2009, 04:33 PM
2000gpgtx's Avatar
2000gpgtx 2000gpgtx is offline
Send a message via AIM to 2000gpgtx
Re: Need torque specs for LIM and SC
11 ft/lbs on LIM and 17 ft/lbs on supercharger
Acc drive end here 11, 1, 3, 10 TB here
5 8
6 7
12, 4, 2, 9
LIM Torque Sequence
Draw yourself a rectangle and mark all twelve bolt holes by the numbers above in that order. 5, 8 and 6, 7 are the bolts internal to the manifold.
I haven't got a sequence for the supercharger, so educated guessing is best .. start in the center and work your way out.
