Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 08-07-2009, 10:51 AM
warrioralumni08 warrioralumni08 is offline
Malibu A/C Bypass Pulley?
I have a 2003 Malibu with the 3.1 and was looking at an a/c bypass pulley and I found one on multiple websites that fits the engine. Problem is I have no idea where to bolt it on at because it looks like it wouldn't go anywhere. Here is a picture of the pulley from one of many websites.
http://www.oreillyauto.com/EW3/Produ...&currentPage=2
Anyone's help would be greatly appreciated. Note that it says, it bolts directly into the A/C compressor place. Well, I have looked at the bracket and where the bolts would go, and it just doesn't seem right because it looks like the pulley wouldn't stick out far enough for the belt to catch it.
Old 08-07-2009, 08:15 PM
bearcatdon bearcatdon is offline
Re: Malibu A/C Bypass Pulley?
Why not just buy a belt for a non a/c motor?
Old 08-10-2009, 09:08 AM
intimadatorsquizz intimadatorsquizz is offline
the a/c bypass pulley goes where the air compressor is.you unbolt the compressor and put the pulley in it's place
all of the 2003 malibu's came with air so there in no belt listed for w/o air so you will need that bypass pulley.
Old 08-13-2009, 01:10 PM
Already looked to see if you can use a smaller belt with no a/c compressor and it's not possible.
Old 08-13-2009, 02:30 PM
rhandwor rhandwor is offline
If your compressor is bad you can buy a new bearing for the compressor. As the compressor is bad you will loose the charge changing the bearing but you will be able to run the car.
A junkyard compressor with a good bearing will also be about as cheap as a bypass pulley. If the clutch is locked try unplugging the compressor.
Without instructions and the kit I've never observed one.
http://www.autopart.com/tools/toolsmain/tool/T_7540.htm
http://www.autopart.com/tools/toolsmain/tool/T_7545.htm
My pullers mostly screw in the front and a bolt pulls the pulley but I do have a puller like this.
