Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-07-2009, 10:19 AM
SICKBOY75 SICKBOY75 is offline
1995 olds cutlass overheating will not run
i have a 1995 oldsmobile cutlass supreme and it wouldnt start so i replaced the fuel pump relay hoping that this would fix the problem. it did and the car started right up but then the car got hot so replaced the thermostat and the car is still overheating.anybody have any pointers for me?
Old 08-07-2009, 12:05 PM
maxwedge maxwedge is offline
A990 racer
Re: 1995 olds cutlass overheating will not run
Clogged radiator, bad water pump, air in the system all are thing to be checked out.
Old 09-04-2009, 10:43 PM
Upstate Upstate is offline
Mine, same description, was diagnosed by a "simple" products of combustion test within the anti-freeze to be a bad head gasket. I had both banks' replaced by a reputable shop and the problem went away. It was explained that since the head and block are different material the different coeficient of expansions can create wear and tear on the gasket and the problem occurs frequently on any manufacturer's vehicle with a similar design. Mine occurred at 100,000 miles but I would guess its more a function of starts that mileage. I quoted "simple" because I never saw the testing fluid for sale or even advertised.
Old 09-07-2009, 02:58 PM
A990 racer
Use that test all the time, not advertised because it is usually done by a " pro" so the market is limited.
