Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 08-07-2009, 09:49 AM
sroney sroney is offline
P0336 Code
I have a 2000 Impala LS with the 3.8L V6. The other day it threw a P0336 code (crankshaft position sensor). The car seems to run fine. What should I start with to try and fix this issue?
Thanks!
Old 08-07-2009, 12:10 PM
maxwedge maxwedge is offline
A990 racer
Re: P0336 Code
Connections to the cps and ign control module from the cps.
Old 08-07-2009, 04:44 PM
Re: P0336 Code
I'll check these connections. Thank you.
Is this a serious issue, or is it hard to tell?
I mean, if the connections look good can I tell if it is the CPS? And if so, how hard is it to change that?
Old 08-09-2009, 09:23 AM
j cAT j cAT is offline
Re: P0336 Code
the cps can be measured with an OHM meter...you have an intermittent problem...so after you see the wiring/connector pins are good,,,,remove sensor and inspect for tip contamination,,,if clean just replace,,,if dirty with metal sludge clean and re-test...
I have found heat causes these to output lower signal volts..even open internally,,,,no good when this happens on a hywy..
Old 08-09-2009, 01:16 PM
Re: P0336 Code
I'll check the connections. If the sensor does need to be changed, how difficult of a task is that?
