Old 08-06-2009, 12:10 AM
efyourself efyourself is offline
89 civic started a light fire!!
as i was driving for about 2 hours, my car just suddenly felt like it was running out of gas when really it was on half a tank a little "popping" noise happened aswell...and my CHECK ENGINE light came on and i couldnt go as fast as i could, it felt like something was cloged in the pipe and was having a hard time to drive...i went to gas station and filled it up, still the same.
as i was 10 min away from my house i notice smoke starts cpmmin from the bottom..i pull over quickly and notice a LITTLE FIRE is starting(around the CAT)..cuasing a slight burn in my interior!
-my car can still start,
-put brand new distributor,rotor,spark plugs & wires and a whole new aftermarket exhaust right after the CAT..new aftermarket headers aswell..(3 months ago)
-i put fuel injector cleaner as well..nothing happens
*the small backfiring happenes where the upper and lower header connects.
*alot of smoke comes from my exhaust causing the bad smell
WHAT COULD POSSIBLY BE WRONG TO MY CAR AN DHOW MUCH IS IT GOING TO COST ME ?!
Old 08-06-2009, 01:03 AM
n_i_c_k n_i_c_k is offline
Re: 89 civic started a light fire!!
you may have a clogged cat. and if you are running a little rich, it could be dumping gas into the exhaust system. the extreme heat from the cat in correlation to a fuel source could have started the fire. I've seen this happen before, the cat got so hot, it was glowing red. This is just a wild guess. this could also cause that sudden loss of power because of too much back pressure. Could be as easy as putting in strait pipe in place of cat. did mine for around 10 bucks. of course welding was needed.
hope this helps.
Old 08-06-2009, 08:26 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Come on man, you replaced everything in the exhaust system except for one component and you mentioned it twice. The "backfiring" is happening because the exhaust gases are building up and looking for a place to go, luckily enough, they have nifty bolts with springs on them that hold your header to your CAT in case this happens.
The answer is only obvious: Apparently your getting exhaust through your header because its backfiring from there, but the car is still acting like something is clogged up in it. You replaced the exhaust system after the CAT so that should be all nice and clear...whats left?
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-07-2009, 02:02 AM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
clogged cat sounds logical. bad o2 sensor too.
Old 08-07-2009, 04:59 AM
Tony's Avatar
TLD Member #1
Bad O2 would cause the car to run rich, but it wouldn't cause it to bog down like something is clogging it and it to backfire at the joint where it connects to the Cat.
Tony
Old 08-21-2009, 04:42 PM
gonna fix the car this weekend..
also found out my car is running on only 1 and 4th cylinder..should i buy the spark plugs first before taking out the CAT?
Old 08-21-2009, 06:34 PM
Tony's Avatar
TLD Member #1
Replace the CAT and go from there
Tony
Old 08-26-2009, 04:16 PM
zodiac5 zodiac5 is offline
oh cripes....
