Old 08-05-2009, 09:46 PM
big brother big brother is offline
1997 ford escort esc L automatic wagon leaky transmision in reverse gear
my little sister owns a 1997 ford escort esc L wagon. recently it started to leak transmission fluid when its put into reverse. it drives fine forward with no leaks. what could be causing it ? when the car is reversed, it leaves trails of fluid. i told her to get rid of the car and take the bus, but with a limited budget and 2 kids, she needs the car. please help
Old 08-06-2009, 02:08 AM
Davescort97 Davescort97 is offline
Escort guy
Re: leaking transmission in reverse only
Welcome to AF!
Check the level of the ATF. It could be over full, giving you the problems you describe.
Old 08-06-2009, 03:29 AM
TheBobsHere's Avatar
TheBobsHere TheBobsHere is offline
Almost any automatic transmission leak means $$$ but just for shiggles, where's transmission leaking from?
Old 09-02-2009, 04:03 PM
zzyzzx2 zzyzzx2 is offline
I once came across a leak like that. It was on a Chrysler, and it was leaking from a pan on the side of the transmission. This side pan was in addition to the regular pan at the bottom of the transmission. Someone before me tried to fix the leak by replacing the bottom pan gasket, which of course, had no effect.
