Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 08-05-2009, 03:47 PM
FiveGrandLaunch FiveGrandLaunch is offline
Exclamation 01 jetta 1.8t overheating
Hey all i just bought a 01 jetta 1.8t and the car has ran great up until a few days ago. The car will run normal at 190 but when i drive it for 5 minutes it goes right up to 240. When im at idle the coolant is flowing but when im driving i dont have coolant flow. What should i do? Replace water pump or.....??? please help me out guys im new to vw's. Thanks
Old 08-05-2009, 09:19 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 01 jetta 1.8t overheating
water pump
use the search function
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 08-26-2009, 07:57 PM
chasonique chasonique is offline
Exclamation Re: 01 jetta 1.8t overheating
Yes definitely check the waterpump mine broke at 60k miles it is plastic... I actually got a metal one put in but just to be safe check this pipe called the coolant flange just recently i had that issue where my car was runnng hot amd that was the issue before u pay someone buy the jetta book im a girl and i put that on myself... You really get ur money worth from buying the book its like 19.99 at ato zone or oreilys but it really help me sae a lot of $$$ my fan went out one time the dealer wanted to charge 1000 just to put the fan on.... I felt so stupid when i got the book it was 3 screws and plug to put it on!!!
Miss Chasonique
Old 09-02-2009, 11:06 AM
SC2ner SC2ner is offline
^^^ 1000? Are you sure it was just the fan. Other wise that is a complete rip. None of the fans even exceed $300 and they certainly are not going to charge you 7 hours of labor. I would expect 1 hour max diag.
But as stated, the water pump is an internal pump. It has a plastic propeller that typically breaks. If you've had your timing belt done, the water pump should have been replaced as well.
Why are you trying to act hard as hell,
when you know damn well
you don't wanna feel the shell
