Go Back   Automotive Forums Car Chat > Renault > Mégane
Old 08-05-2009, 01:40 PM
herveherve69 herveherve69 is offline
oil andfilter change...megane
i have megane dymonique and would like to do oil and filter change myself......is 5w30 oil the right one and where is that filter?
Old 07-15-2014, 07:08 AM
Whizzy Whizzy is offline
Re: oil andfilter change...megane
Hi,
What year is your car year and engine size. Does it use Fully synthetic or semi?
The oil filter is normally a cylindrical thing located on the front of the engine....you may need an oil filter removal tool or you can use a large screwdriver pierced into the side of the filter to undo with.....When putting new filter on make sure you put a little fresh oil on the 'O' ring and don't over tighten...it should go on using your hand until tight then a further quarter turn.
Type of oil could range from 5w 30 to 15w 40 all depends. Where you buy the oil from they can tell you which one you need.
