Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 08-05-2009, 10:27 AM
iceman2 iceman2 is offline
AC and Blower
1997 with 150k miles, passenger front AC is ice-cold while driver's side front AC is obviously warmer; back AC is OK. Front defogger blower only works on driver's side, not passenger side, Replaced cabin filters,
thanks.
Old 08-05-2009, 10:49 AM
roadrunner2 roadrunner2 is offline
Re: AC and Blower
thanks.
I would suspect you have a faulty blend door motor.
The problem with doing nothing is not knowing when you're finished.
Old 08-07-2009, 06:51 AM
Re: AC and Blower
Thanks, roadrunner, is this a difficult thing to fix?
Old 08-07-2009, 12:07 PM
Re: AC and Blower
It can be.
I watched my independent tech replace mine in my '02 Tahoe and it entails pulling half the dash apart to get behind things to gain access to the blend door motor. My receipt says it is called a 'temp door motor'.
The motor cost $80 and the labor of 1 hour ($65) (includes calibration). So, if I had been able to do the work myself, I'd have saved the $65. ($ are CDN)
In other words, it's more time consuming than anything, but once you're there, a couple of screws and electrical connections later and a reversal of the procedure to put the new one in you're done.
Sounds easy, (and is once you know what you're doing) but I'm always afraid I'm going to damage the plastic parts/clips and so on.
