Old 08-05-2009, 10:08 AM
Nitrovreins Nitrovreins is offline
99 silverado problem
I have 99 silverado that i have put a new fuel pump, filter, new plugs and wires. And it still has a sputtering, misfire kinda. Took it to get it diagnosed and two different places said there was no power to plug. Any suggestions?
Old 08-05-2009, 11:05 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 99 silverado problem
There was no spark at one of the spark plugs?
Old 08-05-2009, 11:31 AM
No power to the diagnosis plug but i was just looking at it and everything seems fine under the dash. Thanks for any info
Old 08-05-2009, 11:49 AM
Airjer_'s Avatar
Did they check the cigar fuse to see if it was blown?
Old 08-05-2009, 11:55 AM
Dont think so but i sure will, will that cause no reading though?
Old 08-05-2009, 01:35 PM
Airjer_'s Avatar
Yes, The ALDL has to have a power and ground for a scan tool to communicate through it. If the fuse is blown, there is no communication!
Old 08-05-2009, 03:32 PM
j cAT j cAT is offline
with your engine problem,,,,what is the engine in this 1999 silverado?
Old 08-05-2009, 04:08 PM
Found out the problem, the cigar fuse was blown changed it, had it tested it was #7 cylinder random misfire. Come to find out one of the new plugs that was put in, the porcelain was cracked causing it to misfire. Changed plug, no more problems and no SES codes or light. Thanks for all the help guys.
Old 08-05-2009, 04:09 PM
This is the 5.3 L engine
Old 08-05-2009, 04:53 PM
some plug types you can adj/check the gap...with plugs of this type it is very easy to break the center electrode ceramic...
also if the plug was dropped...
Old 08-06-2009, 12:09 AM
Airjer_'s Avatar
I'm surprised the shop(s) didn't check the fuse?
Old 08-06-2009, 09:46 AM
Looks like they should have known, but im glad i found out on here to check it. Thanks again for all the help.
