Old 08-04-2009, 11:35 PM
happydog500 happydog500 is offline
Fuel Line with the plastic things on the end
My fuel line is leaking. It's the one that connects to the metal line that comes off the top of the fuel tank, to the fuel filter.
I thought they where common, but no place has them. It's only a few feet.
I saw on a post where someone priced one at the dealer for around $70.
Seems kind of steep for a few feet of rubber hose.
Anyone know a place to get fuel line cheaper then $70?
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 08-05-2009, 09:06 AM
maxwedge maxwedge is offline
A990 racer
Re: Fuel Line with the plastic things on the end
Napa has a repair kit for that line made by Dorman Help parts.
Old 08-05-2009, 09:19 AM
big white bufflo big white bufflo is offline
Auto zone has them fuel line repair kit les than 30 $
Old 08-06-2009, 02:37 AM
Already went to Autozone and they said "no, nothing like that, Dealer Only."
Chris.
New Balance 662
Trek 8000
Old 08-06-2009, 08:45 AM
That funny because here in michigan AZ has them before you go to steeler go to rockauto.com there it is 12.07 $ dorman part # 800058 good luck in finding that part some one has it
Old 08-06-2009, 05:48 PM
Mine has the same connections at each end. Can I get one to put on?
New Balance 662
Trek 8000
Old 08-06-2009, 09:10 PM
that is deffinetly a stealer item my sisters bonni i had to replace that onel
Old 08-09-2009, 12:41 PM
Did you do any work on it before it leaked, or did it just start leaking?
Wonder if I could just use fuel line and a couple of those round circle clamps?
Can't figure out why the places on the internet that sell GM Parts have everything but fuel lines?
Chris.
New Balance 662
Trek 8000
Old 08-09-2009, 03:32 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Most national part suppliers have two types of fuel hose 'low pressure fuel hose' and 'fuel injection hose' but you need to make it clear what you want and then check what they bring you! Yes, the worm screw clamps will work fine, we are only talking about 55 psi max!
Old 08-09-2009, 08:03 PM
Just went back and looked. Wanted to be acurate. It's about 1ft. long, not 3.
1ft of rubber or plastic hose for $60+ is a scam.
Should of been an auto dealer.
Others sell fuel pumps, sending units, screens, but no Fuel Lines for a 97 Lesabre.
Chris.
New Balance 662
Trek 8000
Old 08-10-2009, 03:23 PM
Correction: 1 foot of hose $73+ tax at the Dealer.
Chris.
New Balance 662
Trek 8000
Old 08-10-2009, 09:11 PM
HotZ28's Avatar
AF Moderator Elite
Chris, did you read post #9?
Old 08-10-2009, 09:27 PM
Unhappy Re: Fuel Line with the plastic things on the end
NAPA sells the line with one end with the fitting and one end with nothing. We cut one end off and hooked it to the new one.
Fix cost $18.00.
Now I have to take it all off pretty soon and replace the sending unit.
Chris.
New Balance 662
Trek 8000
Old 08-10-2009, 09:34 PM
Without starting a new thread (it's kind of the same part or at least it's connected), I see sending units with two different Codes (HEN, HER and "CRD").
In the pictures they look identical, but one is $42.92 and the other is $116.00.
None come with a pump, so it's the unit itself that looks the same but does anyone know why one is so much more?
Also, anyone want to bet me I have the most expensive one?
Chris.
New Balance 662
Trek 8000
Old 08-10-2009, 09:58 PM
I posted i changed my sisters bonneville hose did you look and see if your line was rusted that is why i needed to change her line and when i changed it it ended up to be the metal line from the sending unit was rusted 130 $ at auto zone and about 4 hr work or you could just replace one side with the repair line
