Old 04-03-2003, 08:38 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
I have a blown ring or four.
Well I talked to guy tonite about my mystery black shit on the rear of my car. He then calls a guy over and tells him to look at it. Its oil. So he goes back up to the hood opens it tells the other guy to start it after he takes the oil cap off he says. "You have alot of blown by I would bet all four of those rings are blown." I said why? "There shouldnt be oil blowing out of the valve cover."
Old 04-03-2003, 09:02 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
sounds like its time for a rebuild.....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 04-03-2003, 09:39 PM
pnut420 pnut420 is offline
That sucks, how many miles you got on it?
'01 Sonoma Extended Cab
Mods: Self Cleared headlights, Snug Top, Indiglow Gauges
Audio: 4 JL W3's, Arc 1500DR amp, MB Quart mids and highs(4" components) 6 1/2 Mb Quart with built in tweets, Seperate MB Quart tweets, Arc 2500, JVC head unit, 0 gauge wiring into 2 4 gauge wires, digital 1 farad capacitor(Stinger)
AF Bay Area Crew
Tony-"And of course DVC speakers are gonna hit twice as hard as a SVC, its twice the speaker.
Pnut420-It has twice the cone material also? Nope!
Old 04-03-2003, 09:56 PM
york2600 york2600 is offline
Send a message via AIM to york2600
Blown rings. That's why I'm doing a b20/vtec now. I figured while I was rebuilding I might as well aim higher. Good luck with the rings. Have you done a compression test to see which rings are blown?
-Tim
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Old 04-04-2003, 09:02 AM
Registered User
No havent done any of that shit. Im just going to drive it until I blow it up. I was planning on a turbo but now I think I am going to wait on that and rebuild with forged pistons and try to beef up the bottom end as much as economically possible. I hopefully can invest about $1500 into the rebuild and turbo project.
The guy that told me it was done for, has a civic with a t-3 turbo and hes running 6 psi.
Old 04-04-2003, 09:48 AM
Registered User
Sorry someone killed the computer I was on and I could just barley hit the send message button. I rode in that guys cars and it is insanely fast we were doing like 160 in the time it takes me to get up to 100.
Does anyone know where I can get a rebuild kit with pistons connecting rods and rings? Everything minus the crank I dont need one of those. Its a d16a6 with stanard bore.
Old 04-04-2003, 12:15 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Lightbulb
http://www.hondaautomotiveparts.com - if you want Honda OEM parts. If you plan to do any boosting etc, then I might recommend some aftermarket stuff, designed to hold the higher loads.
If I blew up a d16a6, and I was planning to rebuild, I would get a ZC (already has 20+ more HP) and rebuild it, and boost to 6 PSI or so.
A junkyard turbo and a rebuilt ZC should run about that $1500 you were talkin' about.
ZC ~ $500
parts to rebuild ~$800 (i used honda/acura oem parts to rebuild my ZC, and without pulling out the receipts, this is my best guess on the cost)
junkyard turbo ~$200?? this might be a little low..I haven't done one of these before...
you could also rebuild it while your a6 is still in the car...so you don't have to have the car off the road
just my $0.02. -
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 04-04-2003, 02:36 PM
darolh darolh is offline
I'm curios as to how he can tell you're getting blow by by removing the cap. Lots of cars spit oil out the filler if you run with it off. The oil is being pumped through the valve train and spit all over the place.
In the old days we used to do things like compression checks.
