Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 08-04-2009, 06:32 PM
xfimpg xfimpg is offline
Tires out of true permanently - harmful?
Hi Everyone
I have 4 tires, that due to a bad balancing machine over a long period of time, have become out of true permanently. Still driveable, but irritating because the whole car shakes.
My question is are there any consequences to keep these tires, ie. harm done to ball joint areas, additional vibrations transmitted to the brakes when stopping?
Michael
Old 08-10-2009, 08:15 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Tires out of true permanently - harmful?
You could lose control of your car as well as accelerate the wear of many mechanical components ! It's not really very safe , be careful if you continue to use them . Good luck !
" Sometimes I grow so tired "
Old 11-15-2009, 09:13 AM
nmikmik nmikmik is offline
+1 on ^ It's very unsafe to keep driving it and you are better off getting a set of (i am usually against them, but if money are tight ) used tires. Depending on the miles on your car the wheel bearings will probably go first.
2014 Camry LE Hybrid - 19000 mi
2014 Chevy Spark EV - 5000 mi
2014 Chevy Spark EV - 3500 mi
2002 Lexus LS 430 - 105000 mi
2001 Volvo S40 1.9 T - 140000 mi
Old 01-04-2010, 08:17 PM
RT Jam RT Jam is offline
Are you sure it's the tires and not the rims. Please define out of true in a number.
Runout at the rim, lateral or side to side or is it the tires for sure?
65 Plymouth Belvedere
69 Dodge Super Bee
87 Dodge Ram
93 Ford Mustang 5L
00 Buick Park Avenue
Old 01-04-2010, 08:26 PM
The mechanic verified the rims on a balancing machine and couldnt see any rims being bent. Meanwhile, he ran his hand on the back of one of the tires and said he could feel the uneveness of the tire.
Other than getting slight-to-moderately irritating vibrations from the steering wheel, this is all I know.
Old 01-07-2010, 04:29 PM
He could veel it but could not see it?
Stop listening to their excuses and put a number on it. Measure the runout with a dial indicator. It only takes about 0.040" to shake some cars.
69 Dodge Super Bee
87 Dodge Ram
93 Ford Mustang 5L
Old 01-08-2010, 07:07 AM
CapriRacer CapriRacer is offline
From the beginning, this sounded like irregular wear - and still does.
There's no fixing irregular wear short of replacing the tires. Nevertheless, the original question is valid - but there's no long term bad effect except for the annoying vibration.
Old 01-08-2010, 05:12 PM
Thanks everyone for your input.
The jury has decided to run these tires for the end of this winter and then junk them.
With about 10000 miles to go on them, it should be tolerable.
