Old 08-04-2009, 03:01 PM
FRANK M FRANK M is offline
98 S-10 2.2 no start
Ok I have a 1998 S-10 with a 2.2 manual trans. I just rebuilt the engine in it. Everything was running ok before I took it apart. Just had some blowby. So I rebuilt it. Now I have it in the truck and it will not fire. I have spark. It has 120 psi in all cylinders. And it has fuel. I can smell a little fuel on the plugs when I take them out. I also here the fuel pump come on when I first turn on the key. What else can it be?
Old 08-12-2009, 09:41 PM
Joe Wilson Joe Wilson is offline
Smile Re: 98 S-10 2.2 no start
If you have spark, compression, and fuel then the only thing left is timing. Did you install new timing gears or remove them and then not get them lined up?
Old 08-13-2009, 02:35 PM
rhandwor rhandwor is offline
You also need air check for a plugged filter or plug in the intake system. But the previous post is more probable.
Old 08-26-2009, 12:13 PM
Yeah it ended up being the cam timing was off. Fixed it.
