Old 08-04-2009, 01:46 PM
pp270 pp270 is offline
Start out shift problems
I have a 3.8 2000 GP GT. The trany fluid and filter were changed at 80K approx. It now has 150K on it. The car is starting to exhibit shifting problems when taking off in some cases. You can tell the rpm runs up higher than its normal shift point before it shifts. This is only between 1-2 gear all other gears shift fine. There are no indicator lights on the dash. Any ideas?
Old 08-04-2009, 10:44 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Start out shift problems
I would suggest to have the trans scanned by a dealer or a trans shop to see if any trans DTC's are stored.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-04-2009, 11:33 PM
troy1 troy1 is offline
AF -Advisor
could be lots of things including engine problems. Does it do it worse cold/hot?
Old 08-05-2009, 09:13 AM
so far it has just done it cold.
