Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-04-2009, 03:15 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
Direct port nos injection
Hey I was looking through websites and reading reviews and tech write ups and so forth, im in the planning phase of coarse for my 99 gsx, im having trouble finding a direct port nitrous kit...
most of the places ive seen only make wet, or dry kits, and you just tap the hole, ect.
so, i guess my question is, is every car different and u have to make your OWN direct port setup via some tube bending and fuel/nos plumbing??
or what?
I see how people take their intake manifold out and drill holes in the runners, and i saw where one guy did that, and then bent the tubing himself, and whatever, is that what you do? or does the "direct port kit" come with something that otherwise wouldnt come in another kit? would I just buy four fogger nozzles? and a few solenoids...or....
thanks!
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 08-04-2009, 04:00 AM
Re: Direct port nos injection
-on a side note-
instead of starting another thread...
i was curious, i wasnt going to ever put nitrous on my rs bc, of coarse, its fwd, and ill spin like a record...
however i found this kit...
http://www.zex.com/Pages/84/Turbo-Equipped.aspx
so maybe that more tame kit will make good friends with my traction...
my question is, my fpr has three places with which you can tap a line, and all of them are being used...one of them is being used for a fuel pressure gauge...
so, if i WERE to install this kit, assuming id run the fuel to the nitrous via the fpr, would i just get like some sort of hub to add to one of the fpr ports, so i could plug up the fuel line AND the gauge still be used?
Old 08-04-2009, 06:04 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
You could bend tubing yourself like that guy did or use SS hose. I have also seen some people just use 1 nozzel and tap it right before the TB. I have never used nitrous so Im not really sure on which way is better. 1 nozzel would deffinately be easier but if you plan on running a lot of spray DI is the best option so you know the nitrous is being distributed evenly.
And yes you will need to split your fuel line to feed fuel to the solenoid
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-04-2009, 08:18 AM
awesome...
thanks man
so, hows the best way to split the outlet? do they make a part like a splitter or...
Old 08-04-2009, 10:07 AM
Holset powered 420a
Yea you should be able to buy a T or something
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-22-2009, 10:34 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Personaly If you have the extra money DPNI is money well spent if you are looking at a NIS. You have much more flexability, a better flow distribution in the intake runners and is fully adjustable depending ont your intake design!
DSM geek
Old 08-23-2009, 11:27 AM
well, of coarse ill start out small...play it safe.
and from the research ive done, it seems pretty safe so long as you play by the rules lol...
i dont even know what limit i wanna go for...like can someone tell me a ballpark figure of how much i prop shouldnt be going over...or an amount to shoot for...
Old 08-24-2009, 11:12 PM
Well, IIRC they don't recomend less then a 75 shot with Dirrect Port. I would start there if you're serrious. I had a JMFab SMIM with No2 bungs and a Zex 4cyl dirrect port nitrous injection that I never did install. Definitly get a SMIM and kit at the same time, and if you can go with the soft lines. I think with your mods your quite safe with 75-125 shot.
DSM geek
Old 08-25-2009, 08:21 AM
smim?
yeah, its not going on this car lol, another one, with far more superior mods(in time)
my car now sounds like it has a drummer inside of it
BINK TINK TIC TAC
its knocking like crazy in other words...
Old 08-25-2009, 08:48 AM
Holset powered 420a
sheet metal intake manifold
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-25-2009, 11:27 AM
oh ok, thanks
for the gsx im building, ive been looking into the crate motor from magnus motorsports...not sure if it comes with a smim or not...or if it even comes with one at all...
but yeah..thanks for the info guys
