Old 08-04-2009, 12:34 AM
rayh2 rayh2 is offline
Send a message via ICQ to rayh2 Send a message via AIM to rayh2 Send a message via Yahoo to rayh2
1989 Civic Starting/running problem
This is an 89 Civic with 145K miles, autotrans. It started out as an acceleration problem hesitating a little but has gotten much worse. It idles OK but once it shifts into third gear it will start to hesitate sputter and die. (Very dangerous on the freeway !). Then it is real hard to start back up again. I kind of think its fuel related but you guys are the experts. Tonite on my way home from work it stalled 5 times mostly when going up a hill. I've checked most of the posts for this type of problem but none seem to fit. Any ideas will be appreciated.
Old 08-21-2009, 06:10 PM
nick_mech_area51nw nick_mech_area51nw is offline
Re: 1989 Civic Starting/running problem
it could be you distributor. start your car let it run till it dies. make sure it doesn't run out of fuel. if you think its safe drive it till it dies. then take the number one plug out and check for spark if there is none its your distributor. if there is spark then i would say fuel. cant say until you reply back. let m e know if this helps
nick_mech_area51kustoms
Old 08-29-2009, 07:01 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
well, as far as i have learned from extensive reading, because of my restoration of my 91 civic, you have 2 seperate issues:
1. hesitation during driving and stalling is ignitor related
2. no starts is main relay module.
ignitor is inside the distributor.
main relay is hidden under the dash trim, next to your left knee. i replaced mine today, $45 shucks. took about 20 minutes and some cussing.
http://www.tegger.com/hondafaq/start...html#mainrelay
btw, no need to remove hood latch. just pry plastic trim away and you can undo the 10mm bolt that holds relay in place and take it out easy.
http://www.tegger.com/hondafaq/ignit...adigniter.html
Old 08-31-2009, 07:34 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
what code are you throwing
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
