Go Back   Automotive Forums Car Chat > Racing > SCCA Racing > Pro Racing
Old 08-04-2009, 12:43 AM
andrew1984 andrew1984 is offline
Incase you didn't know, Volkswagen Jetta TDI Cup car specs!
The Jetta TDI Cup car is powered by a 2.0L, 170 HP, four cylinder TDI clean diesel engine mated to a six-speed, double-clutch, automatic DSG transmission.
The car is only slightly modified from stock with Pirelli racing tires, race suspension and brake components, drivers racing safety seat, FIA roll cage and an on-board fire extinguisher system.
Specs:
Engine capacity: 1968cc, 4 valves per cyl., 170HP, 258 ft-lbs tq @ 1900-2500 rpm.
Fuel: Hyperfuels SynDiesel B5 Biofuel
Brakes: Fronts\\ 4-piston fixed-caliper disc brakes, internally ventilated, 356mm (14")
Rears\\ Single-piston floating-caliper disc brake, 255mm (10")
Wheels: 18x8.5" light alloy rims
Tires: Pirelli 245/645-18" slick and rain tires
Curb weight: 1,290kg (2,844 lbs)
Data logging: Memotec AIM data logging system with display
Safety: ABS brakes, 6-point racing safety harness, DefeNder head and neck restraint system, FIA approved roll cage,
FIA homologated fire extinguishing system, recovery hooks front and rear, electric cutout switch, driver side window safety net, Recaro race seat
http://www.makehasteracing.com/
http://www.trackmart.ca/
http://www.vw.com/
http://www.scca.com/
http://www.can-alignment.com/
http://www.hotbits.ca/
http://www.hyperfuels.com/
Andrew .Volkswagen. Cordeiro .:R
Email: [email protected]
1975 Volkswagen Scirocco #91 EM
2009 Volkswagen Jetta TDI #26 TDI Cup
