Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-03-2009, 08:46 PM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
exhaust manifold studs
I have been searching through parts magazines, and surfing online, for a good set of exhaust manifold studs, bc one of the ones on my 420a sheered off, it was the damdest thing...
back when i first got the car, i was running it a few times on a closed off road, and stopped and checked under the hood for something or another, and as I was looking...PING!
i was like, wtf was that, and almost 2 seconds afterwards, i heard something hit the ground by my feet, so i looked and got ready to pick up the object, and realized what it was....so i picked it up with a pair of grips, and sure enough, it was a sheered off exhaust mani stud.
Ive been searching all along for a set of these little boogers, and usually if i find soem they are not for my specific car, and usually the sets that i find for other cars are about 2-3 bucks for a set of 12 or whatever...
just 5 mins ago i randomly ran across this:
http://www.cimotorsports.net/motor-s...alon-420a.html
now, im curious, as to why these are significantly higher priced than the ones ive been finding, or is just bc its ARP, and also, if ay of you know from experience, if these will fit my car...
Thanks!
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 08-11-2009, 10:19 PM
Re: exhaust manifold studs
Nobody knows anything about these?
Old 08-11-2009, 10:40 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Yes those are expensive because they are ARP. Advance auto sells exhaust studs. You dont need any that are 420a specific. Just M8x1.25 thread. They are even on the shelf
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-12-2009, 12:00 AM
so, its not a matter of needing sometig stronger than stock...unless i just wanna spend the extra cash on it...
maybe they ALL just need replacing...
Old 08-12-2009, 06:09 AM
Holset powered 420a
You shouldnt need anything stronger than stock. If they continue to break maybe you should upgrade them.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-12-2009, 01:44 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
I dont own a 420a, but I too was having problems popping exhaust manifold studs.
I upgraded to ARP stainless exhaust studs.....they work awesome! No more problems.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 08-12-2009, 02:43 PM
steviek's Avatar
steviek steviek is offline
Ironic I broke one of mine yesterday
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 08-12-2009, 08:11 PM
I highly recommend the ARP's. I take my manifold off, what feels like once a week. Havent had any problems with my studs, they're great.
Caleb
vanilla gorilla
Old 08-12-2009, 08:23 PM
once a week? what for?
and yeah, ima get a set of cheap ones for now, but ultimately ill get the arp's...bc they make good stuff
Old 08-13-2009, 01:30 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
You might want to check these guys out too. I'm not sure if they have them for the 420a, but it's worth a look.
www.ssstuds.com
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-13-2009, 08:15 PM
oh thanks man, ill def check them out
