Old 08-03-2009, 08:19 PM
Zboom Zboom is offline
Exclamation Car bogs or dies when accelerating. I can't figure it out!!!
When pushing on the gas, the car bogs down, or dies. If you get up to speed slow, its fine. Giving it constent gas, its also fine. But if you let off the gas, and push it again, it starts over. I have changed
Fuel pump
Fuel filter
Fuel injectors
MAP sensor
Air filter
O2 sensor
Throttle control piston and sensor
My brother changed the comp and a couple other sensors. Can't remember the ones he changed.
I also changed the spark plugs and wire.
I have no idea what to do now. I have had a couple of mechnics also look at it. They didn't know. The car is a 1990 Pontiac Grand Prix SE, with a 3.1T motor. It also only has 100,000 miles on it. I'm going broke, so any help would be great.
Old 08-03-2009, 09:20 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Car bogs or dies when accelerating. I can't figure it out!!!
Rent a fuel pressure guage from advance or oreilley's and check fuel pressure. Report back with your numbers of fuel pressure key on engine off, and engine running at idle.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-04-2009, 12:00 AM
wlkjr's Avatar
wlkjr wlkjr is offline
What about the catalytic converter or muffler? Your symtoms sound more like these would be your problem.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 08-04-2009, 08:02 AM
Thanks guys. I'm gonna check the cat out today.
Old 08-06-2009, 12:53 PM
My Brother said he checked the fuel pressure gauge, and it was around 40 off, 45 on. Like 37.6, but could remember exact numbers. Have not tried the cat yet, and the 02 sensor wasn't changed. My mistake. Could it be the 02 sensor? We also found no breaks in the wiring, it all looked good.
