Old 04-03-2003, 08:09 PM
D[X]P's Avatar
D[X]P D[X]P is offline
Send a message via ICQ to D[X]P Send a message via AIM to D[X]P
problem
ok i ran into a few problems
my revell saleen i guled the engine on but it seems slanted
how can i un-glue the engine?
problem 2
i got some glue on the dash board
how do i remove/camuflage it?
thanks
Failure is only the opportunity to begin again more intelligently.
Old 04-03-2003, 08:45 PM
Vyacheslav's Avatar
Vyacheslav Vyacheslav is offline
Send a message via ICQ to Vyacheslav Send a message via AIM to Vyacheslav
for the dashboard, try sanding the glue off, and repainting the spot. I know if you used cement, it could melt some of the paint and plastic, so carefull sanding should fix it.
Recently completed models:
JGTC Mobil 1 NSX
Porsche 911 gt2
1985 Toyota Corolla AE86
Old 04-03-2003, 08:46 PM
D[X]P's Avatar
ok thanks a lot
Old 04-03-2003, 08:54 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Try putting it in the freezer for a hour or two so the glue can freeze and you'll just be able to snap it off.
Old 04-03-2003, 09:05 PM
Chain's Avatar
Chain Chain is offline
Oooh, an idea which never cross my mind, good suggestion.
Just hope my other parts attached to it doesnt snap too.
To each his own!
Read the FAQ you faqer
Evo Meet....coming to a forum near you!
Completed!-Click on Pic:
Projects done and posted:
Subaru WRC2001 RGB-My first project in AF Click Here
In stocks:
Ferrari F1 2001
Tyrrell P34
CLK Warsteiner
Ford Performance Blue
Ferrari Enzo
Opel Team Holzer
Williams FW24
Old 04-03-2003, 10:08 PM
D[X]P's Avatar
wouldnt the plastic crack??
Old 04-03-2003, 10:09 PM
Chain's Avatar
I think the glue should snap before the plastic does, should be safe.
Not sure though havent tried this technique.
To each his own!
In stocks:
Ferrari F1 2001
Tyrrell P34
CLK Warsteiner
Ferrari Enzo
Opel Team Holzer
Williams FW24
Old 04-04-2003, 05:08 PM
D[X]P's Avatar
im gona try sanding
Old 04-04-2003, 05:09 PM
D[X]P's Avatar
oh yea i forgot to ask this
i got a litle paint on a decal so would the decalbe ok if u use paint thinner to take off?
Old 04-05-2003, 02:18 AM
I didn't know freezing the car make it easier!
DXP, I'm positive that it'll ruin the decal, because it'll treat it as a residue! But, why don't you test it out on the "scrap" pieces of the decal sheet(ex. kit# or name).
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 04-05-2003, 10:01 AM
D[X]P's Avatar
ok good idea!
thanks
Old 04-05-2003, 10:31 AM
freakray freakray is offline
AF Modelrater
Not unless you make it....the glue become britttle before the plastic does, so the amount of effort to remove the engine would be less than it would be to crack the plastic.
BTW, the freezer trick is a tried and tested method of getting parts apart.
AF User Guidelines
Old 04-05-2003, 10:39 AM
D[X]P's Avatar
how long do u leave it in the freezer? 20 mins?
Old 04-05-2003, 02:21 PM
freelunch's Avatar
freelunch freelunch is offline
The freezer trick is really only for tube glue I think. Liquid glue contains lots of plastic solvent so it will weld the plastic together.
