Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 08-03-2009, 04:49 PM
wayfastracer8 wayfastracer8 is offline
conversion
ive got a 1998 cavalier that is wrecked and i am going to fix but it has an automatic tranny in it. the guy im getting it off of is giving me all the parts to fix it and the car for free. wat do i need to do a total engine swap from a 2.2 w. auto tranny to a 2.2 with manual tranny. he has several engines in great shape with manuals on them up there. ive done engine swaps b 4 but not engine and tranny but my dad says not to do it but i want to and he isnt doin it so i dont think he should complain. anyway i will rebuild the engine that i put in it. cam, crank, pistons, valves, etc.
Old 08-04-2009, 03:06 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: conversion
The engines are the same, just need to remove the flexplate and install a flywheel (probably need longer bolts for the flywheel, and use loctite on them). You need to weld a bracket on the frame that isn't there for the A/T and cut off the one that is there. And then of course you need every part for shifting (clutch pedal assembly, master cylinder, shifter, cables, etc.) I believe you also need the center console from an M/T car to make it look right.
I'd listen to your dad on this one, way too much work for a car with 115 HP.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 08-09-2009, 02:24 PM
Re: conversion
ok i dont think im going to do the converison now cause i found a turbo kit for an automatic transmission. where can i get a stronger crank and lower compression pistons for a 2.2
Old 08-10-2009, 04:06 PM
J-Ri's Avatar
Re: conversion
No idea... but when they say the turbo is for an A/T, it only means the pipes will clear an A/T, it should still work for an M/T. Also, the 2.2 OHV is not worth putting a turbo on. It's an old design truck engine, doesn't belong in a "performance" car. It would be my number one choice for reliability, but very low on the performance list.
Old 08-30-2009, 10:19 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: conversion
www.carcustoms.net
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 03-26-2013, 12:18 AM
ole hornet driver ole hornet driver is offline
Re: conversion
k was goiing to try a change over on one of my parts cars, think you have to punch a hole in the firewall for the clutch cylinder too don't ya? didn't see anything there that looked like a plug.
