2002 bravda awd light on
hi i have a2002 bravada with 80k on it the awd light just came on this week , but it dosent stay on all the time , it comes on in the early am ,on my way to work , but on the way home when its hotter it stays off? or when you first drive it it feels like its in 2wd all the time ,
i did read all the threads about this but am a little confused, i dont have4 the exact problem its not enaged, i did take the car in a while ago for that rubbing while turning the dealer replace a sensor and changed the fluied in it , i was told by a mech not to take the atc fuse out , he said the light would stay on all the time ???? he also told me it was ok to drive it that way ????? any help has anyone had this on again off again awd light? Last edited by addairgar@comcast.; 08-03-2009 at 04:42 PM. |
Re: 2002 bravda awd light on
Same issue here. I have a 2001 Oldsmobile Bravada. Began Sept 2007.
My husbands grandfather was trying to pull a small boat. Well the AWD light came on and its been on ever since. The actuator was replaced, the TCCM was replaced, checked all fuses and ground wires and the light just wont go out. Drives fine, and dealer says it still works. Tried to pull codes but comes up with nothing. Most bizarre case I have ever come across. |
Typically when a transfer case code is set, it needs to be erased by the scan tool. It won't automatically clear like most OBDII codes. Did the dealer erase the codes?
